Overview
Attached script example show how to rename Report Browser slide names, and use string replace syntax.
Pre-Requisite
Have Report structure set up with at least 1 slide.
Edit attached scripts either w.r.t.
 variable "NewName"
 or directly for term in brackets in line
 ::ardi::item set -id $i -name "MySlide $count"
 to define the new slide name as desired.
User's HyperWorks session should contain Report structure with at least 1 slide.
 Execute one of the example scripts.
 Start:
 Run script
 Result of script "rename_Report-slides_KB1.tcl"
 Result of script "rename_Report-slides.tcl"
