Overview
It is often difficult to update all the holes in a set of surfaces to be of the same density. This script automatically updates hole densities to a specific density or according to a mesh size. There are actually two sub scripts - the first is fully automated, finding the holes and then adjusting their sizes. The second is more interactive, it requires the user to select the holes, then updates the selected holes to a specific density.
Simply mesh the part with automesh, then run either script. It will ask if you want to specify density or mesh size, then allow you to input the size or density to use. The attached video shows the usage in greater detail.
Limitation
Functionality
Meshing
Subfunctionality
2D Meshing
