How to create load time history for fatigue analysis? please help ...
I,m doing it for wheel hub
Hi
create a TABFAT load collector and mention the Yaxis (i.e) load data.
For applying a Fatigue load 4 load collected are needed
1. TABFAT
2. FATLOAD
3. FATEVNT
4.FATSEQ
once TABFAT is created call this load collector in FATLOAD, Simillary FATLOAD should be called in FATEVNT and FATEVNT should be called in FATSEQ.
For better understanding Pls check the Help https://connect.altair.com/CP/SA/hwhelp/2019.1/os/topics/solvers/os/fatload_bulk_r.htm
Regards
Shrinaath
