Overview
Create regular polyhedrons (solid geometry) giving its centroid and side length. Available polyhedrons are: hexahedron, tetrahedron, octahedron, dodecahedron and icosahedron. Once created, user can move and orient the polyhedron to desired location using "position" tool.
1. Unzip the compressed file.
2. Keep the folder "Images" in the same location of the script.
3. Execute in HyperMesh the script "RegularPolyhedrons_v1.0.tbc" (File > Run > Tcl/Tk Script).
Limitation
1. In order to avoid some geometric issues, side length must be >= 0.005. After the creation of the polyhedron, user can scale it if this is wanted.
2. Centroid node must exist (mesh node or temp node, do not use "quick node selection").
Functionality
Geometry
Subfunctionality
Creation
