Hello everyone,
 I am kinda a new user of CAE and Hypermesh and this is my first question in this community. I am trying a create a contact between a sheet metal and injection molded plastic part. By considering their thickness to lenght ratios, I modelled both parts with shell elements.
 I am considering the parts as the plastic part will be assembled the holes of the sheet metal part. I am planning to observe the structure's torsional strength with OptiStruct and applying a contact with a friction between the parts. The gap between the parts is approximately 0.5 mm.
 I could not manage to create a contact since the parts are not located on top of each other with respect to their normals. I thought that maybe I can model the parts with 3D elements but since the sheet metal thickness is too low, I will need to use very small elements.
 I am kindly asking your ideas for how to apply contact to efficiently simulate this scenario. Thanks in advance.
