warnings in boundary condition while running simulation
I am getting the following Potential errors in Boundary condition.
*** WARNING: Duplicate convective_heat_flux element BC for surface 398392879 set "inter_AL_AIR quad4 AL pyr5"
*** WARNING: Duplicate heat_flux element BC for surface 398388637 set "inter_AL_AIR quad4 AL pyr5"
*** WARNING: Surface 398105821 of element BC "inter_sair1_fAIR tria3 sair1 wedge6" is in the interior
*** WARNING: Surface 398111596 of element BC "inter_sair1_fAIR quad4 sair1 hex8" is in the interior
What should i change as these interface surfaces dont exist while meshing in Hyprmesh
What is your simulation model? Multiple volumes? Fluids and solids, etc? Can you share additional information, images, etc?
0 -
its basically air inside aluminium frame.
i have added air into different components for ease of getting the location specific temperature values
0 -
Have you deactivated the boundary conditions on the surfaces between fluid volumes (where there should not be walls)? Are you setting this up in HyperMesh?
0 -
No, I didnt deactivate Boundary conditions
I thought it wont make a difference. Will it ?
0 -
Are you setting this up in HyperMesh? Or a different tool?
If boundaries between fluids are written as type = wall, you will get warnings as you show. If they are written as type = auto_wall, you should not get those warnings.
You may want to try HyperWorks CFD for problem setup, as the HM interface hasn't been updated in a while, now that there are other tools to use.
0 -
but what effect will there be if the Boundary condition is turned off? Will the results be incorrect
0 -
If these are surfaces between different portions of the same fluid - not an actual wall - they should not have any boundary conditions. (type = auto_wall takes care of that, too). If it's a true boundary - like a physical wall - then, yes, you need the boundary condition.
Maybe attach the complete .inp and .Log files.0
