I want to model natural convection of air inside a closed chamber(2 walls with temp and 2 Adiabatic).
Which turbulence model/laminar would be best suited for such simulation
I would typically recommend Spalart-Allmaras, as it works well across a broad range of applications and is only one extra equation instead of two, but you can certainly try others and see how the results of interest change.
