Hi guys,
i am working with an assembly which is mounted with SPC. Now i want to simulate this model with a gravity force of 30g in the x direction on the whole assembly. i simulated some masses on the assembly with rbe3 elements and assigned the masses to the dependent node of rbe3 element. then i applied a load collector with grav card, entered 30 in G section, 1.0 in N1 section and defined the loadstep with SPC and gravity load collector. it does not work, how do i do that?
unfortunately i cannot share the model but i still hope to get some help
