I built up a Tension analysis wit a coupon speciment.
Material: LAW12
Property: P6_SOL_ORTH
I want to set up the materialorientation. I tried to assign the nodes to a coordynatesystem, which is rotated by 45 grad and tried to set the parameter 'Psi' on 45 Degree, but neither of them worked. Can you please help me by building up a laminate?
## Orthotropic Solid Property Set (pid 6)
/PROP/SOL_ORTH/1
solids
17 2 3 2
1
45.0
