Hello!
At some calculations I am able to see the results in the h3d file. I dont have to wait until the calculations are finnisched. Which ist ist Keyword, which with I can control it?
Thank you for your help!
Best regards.
Hi migid
You can open the animation files individually also. The animation files (A01, A02, etc) will be written in the run directory.
If this was not what you asked, can you please explain more about your need
Hi Pranav,
thank you for your answer, that works actually.
Thanks for the update
@migid
You can use HV Trans software to convert A0 files to h3d file.
You can check T01 file to check the energy, velocity, acceleration up to solved time.
