Overview
This feconfig file provides the configurations to get fastener realized with Abaqus COUP_KIN instead of KIN_COUP
copy this feconfig.cfg in your HyperMesh start-in directory (By default My Documents), then open HyperMesh again
If you load the file as is, you will have access to both kin_coup and coup_kin realizations in HyperMesh.
If you want just want to overwrite the kin_coup representations, open the feconfig.cfg. Each representation has a unique identifier right after the string CFG abaqus:
CFG abaqus 98 hinge coupkin (b31)
*filter bolt
*style bolt 0
*head
rigidlink 9 12
*body 0
bar2 9 1 dofs=4
To overwrite the existing representations, please remove the first digit of each representation identifier (the 9 on prefix), then save again the feconfig file.
