Overview
minlinelength.tcl -- This Script finds the min and max line length in the HM database. It also creates temp nodes at the start and end points of the line with the min length for further investigation This can be used to find the correct element size for meshing
Within the HyperMesh, File>Run>Tcl/Tk Script or, from the command window> source minlinelength.tcl ( make sure you are in the right directory).
Functionality
Model/Analysis
Subfunctionality
Model Info
