Optistruct - large contact forces
Andy@LamteqSolutions
Andy@LamteqSolutions Altair Community Member
Hi All,
I seem to have a recurring issue and it doesn't seem to make much difference if I use S2S or N2S.
I have a number of very similar models, all set up the same way and I would only expect a mild difference in stress distribution and contact. What I get is with some of the loadcases I have an extremely high contact force. Now I've encountered this before and have needed to switch to gaps but this time I really do need the contact forces exported.
Here are some notes.....
NLPARA = NINC 10
PARAM = CNTSTB
Contact card  = Adjust = auto, type = slide, MORIENT = Norm.
In general, slave contact surface is smaller mesh size.
<?xml version="1.0" encoding="UTF-8"?>CONTACT_ISSUE_STRESS.thumb.jpg.00abbe5f6539bc261a86b13b6ca35d74.jpg<?xml version="1.0" encoding="UTF-8"?>CONTACT_ISSUE_FORCE.thumb.jpg.4c3ed111a17f2a21970197f3781640f3.jpg
I've added some images....
  • Mario_21478
    Mario_21478 Altair Community Member
    edited December 2018
    Hello Andy,
    In your case, I would recommend the following for the CONTACT card:
    TYPE=SLIDE
    MORIENT=OPENGAP
    SRCHDIS= check your distance, small value
    ADJUST=NO (be carefully with AUTO, I would not take it!!)
    CLEARANCE=0 (if it is a closed contact at the beginning)
    DISCRETE=S2S (contact is smoother, better in general)
    Try the model without friction first, if it works fine you can add friction.
    Best Regards,
    Mario
  • Andy@LamteqSolutions
    Cheers Mario,
    Will give it a go and let you know.
    Kindest regards
    Andy
