Contour plot for pressure and thermal loads
Hi , I have large amount of nodal temperature loads applied on the model. Is there any way to visualize the temperature load using contour plots in hypermesh.
Also , incase of PLOAD cards applied on the elements. Can we visualize applied pressure in hypermesh using contour plots?
Thanks in advance.
Girish
Hi Girish,
You can visualize the applied loads but I did not understand what do you mean by contour plots. There is no contour plot panel in HyperMesh.
0 -
Okay. What is the option for visual verification of pressure and thermal loads in hypermesh.
0 -
Hi Prakash,
I found an option in Hyperworks Engineering Solutions Aerospace user profile.
There is an option 'Fields' which plots contours.
Can I get more details for using this option.
Thanks
Girish
0 -
Hi Girish,
Which results are you looking to plot?
You can use Apply results from Post Process page but it is suggested to use HyperView for post Processing.
I am attaching about Fields fyi
0 -
Hi Prakash,
I intend to plot applied temperatures using contour plot.
Thanks for the document.
Girish
0 -
Hey Everyone,
I am also interested to visualize the applied temperatures as contour plot.
Anyway to do this in hypermesh ?
0 -
Altair Forum User said:
Hey Everyone,
Hi @evsm1982
What is the solver you are using?
If it is OptiStruct, please use OLOAD to output applied temperature load.
0 -
Hi Prakash,
Thanks for your reply. Yes I am using Optistruct.
I guess using OLOAD can do the trick but is there any way to do this in Hypermesh without the need for running a solution?
0 -
Hi Prakash,
That's it.
Thanks a lot!
