Flux is a finite element analysis tool for low frequency magnetic and electric fields. In addition, Flux solves thermal conduction problems. Rigid body motion is included in Flux (rotating, translating or pivoting motions). External circuit connections make Flux the tool for electromechanical design including the power supply.
This training is aiming at learning the use of Flux in order to be able to analyze an electromagnetic device in 2D or in 3D. Mainly dedicated for the beginners with Flux. At the end of the training, you will be able to create your geometry, to define material characteristics to represent electrical circuits. Numerous classical analysis will be presented on known cases based on electric motors and actuators examples available from the supervisor.
This training is the first one of a series of three. They are dedicated to the following topics in the given order:
- Geometry and Mesh
- Physics (Magnetic Application)
- Solving and Post Processing
It is recommended to participate in all three trainings, but it is not mandatory.
Prerequisites:
Knowledge of the Finite Elements method and knowledge of theoretical aspects of electromagnetism. Flux installed with a valid license.
