Currently I am doing P-FSI with VWT 2017.2. For this purpose I have looked at the instructions on this topic by Ratzel and Nainani. I have two questions regarding the generation of stiffness information about eigenmodes.
1. Is it pointless to carry out the eigenvalue analysis for a single component without spatial fixation (with the consequence that one would have six rigid body modes)? Or can VWT via AccuSolve handle it?
2. Suppose I have an assembly that is made up of several components. Only one component from this assembly is to be exposed to a flow in the VWT. However, in order to map the correct deformation of this component due to the flow, one would have to know the stiffness information of the whole assembly (the components are mechanically coupled in the assembly).
Is it possible to generate the eigenmodes for the whole assembly and assign them to the one component (via OP2 in OptiStruct) that is considered in the VWT so that this one component combines the stiffness information of all components?
