I stuiied impact analysis in Master and Used Ls dyna
I used sensor and automatic termination
I created two termination criteria;
if rigid plate velocity is smaller than 0.01 analysis will be terminated
if tube deformation reach at 50 mm (or half of tube height) analysis will be terminated
I wanted to perform analysis using this same criteria in RADIOSS
