I want create boundary conditions via spring instead of fixed - free cantilever beam
Can you please explain a little in brief?
Normally for a fixed - free beam, we was constraining all freedoms (T and R) at fixed end
I want to use spring at fixed end instead of constraining all freedoms in order to agree experimental modal results
what I want that
You can use CELAS or CBUSH element which will be fixed at one end and provide stiffness to the spring in the desired direction.
