hi everyone,
I have run my model but the software do not create .h3d file
best regards
<?xml version="1.0" encoding="UTF-8"?>hi moderators,
Just edit the EIGRL card..Just set the ND (no of modes) value to 25 and remove V1 and V2.It should run and generate h3d.
thank you for reply but I solved this problem as you said
you can close this topic
