Hello!
I am new to Hyperworks and trying to analyze a simple beam as a simply supported cantilever structure. When I try to run the analysis with optistruct, an error "Syntax error in the path or filename" comes up. I check online and people say this is because I didn't set a filename in CONTROL CARD > ASSIGN > PUNCH. I tried to type the filename in but the box seems to be greyed out. Does anyone know how to add the file path in this case? Thanks!!!
