In this video we are covering Symmetry Intersection check for removing duplicate reports at mirror location contributed in reducing reports and increasing performance. Based on few customer feedback 30% efficiency is shown during the session.
Match function uses Shape AI code for recognizing connection data, multiple instances of solids managed in same part are now managed as single part which allows flexibility in converting 3D CAD to HW Connectors
New surface deviation comparison for the quick and accurate CAD vs CAD comparison process. In this topic we covered the past 2 methods and current new methods and its comparison results.
For the first time MVD is able to compare cards and its content via Detailed Comparison in addition to shape comparison. Most of the major solver is supported. With a simple clicks user can understand the mismatched cards and parameters.
Other slide contains minor enhancement, CAD Thickness is calculated same as normal comparison. Meshing unmatched components is not working in Batch and others
The last slide covers few bug fixes reported by user. Please feel free to contact our AEs if you need more details on these new function.
