Altair SimLab Newsletter : Edition Apr 26, 2024
The following are the features available in the latest SimLab 2024 Beta delivery.
Solution: Particle Flow
Solver: AcuSolve
- Translation/Rotation: Particle Flow solution > Analysis > Boundary conditions > Mesh motion
- Support for mesh motion is further extended to simulate the following types.
- Linear Translation
- Linear Rotation
- Sinusoidal Rotation
Solution: Non-Linear Static / Transient
Solver: OptiStruct
- Results Request: OptiStruct Non Linear Static / Transient Solution > Settings right click
- Support added to request creep strain energy output for set. Also, it can be defined in load case output request.
Thanks & Regards,
Santhoshkumar
Sr. Manager, Quality Assurance
Altair | Nasdaq: ALTR
santhoshkumar.sundararajan@altair.com | altair.com
Connect with us: LinkedIn | Twitter | Facebook
#OnlyForward
SimLab learning center (SLC) | SimLab FAQ
This message is a private communication intended only for the use of the addressee and may contain information that is PROPRIETARY and CONFIDENTIAL. If you are not the intended recipient, you are hereby notified that any dissemination of this communication is strictly prohibited. If you have received this communication in error, please erase all copies of the message and its attachments and notify the sender by replying to this message. Thank you.
