This document shows the compared simulation results of the rectangular patch antenna by using two different feeding methods: Pin-fed and Coaxial-fed.
Overview of the Simulated Antenna
1) Original model: A.8 Microstrip Patch Antenna from Feko’s example guide
2) Antenna dimensions: Unit = mm, Radiator/Ground = PEC
3) Simulation frequency: 2.7 ~ 3.3 GHz
4) Simulation solver: MoM
Two Feeding Methods
1) Pin feeding
- How to construct: Vertical line (length = substrate height, 2.87 mm)
- Port setting: Wire port
- Source setting: Voltage source (Reference impedance = 50 Ohm)
2) Coaxial (cable) feeding
- How to construct: Two cylinders (length = 10 mm)
- Port setting: Waveguide port
- Source setting: Waveguide source
- Watch the following video for the details.
Comparison of two Reflection Coefficients
Conclusion: Simple Pin feeding can replace Realistic Coaxial feeding for microstrip patch antenna simulations.
