A very interesting technical paper using Altair Inspire Print3D on Material Behavior of a Three Blade Propeller Using Metal Additive Manufacturing Techniques was published which uses Altair Inspire Print3D for undergoing thermomechanical analysis which helped researchers in studying the material behavior along with the position of the part that had been chosen, read the Full Paper here - Material Behaviour of Three Blade Propeller Using Metal Additive Manufacturing Techniques (hindawi.com)
