Hello !
Check out these two Altair Community articles about new FluxMotor tutorials.
FluxMotor Overview Tutorial
First tutorial (link) is about showing how FluxMotor software can be used as a starting point to run first performance analysis and choose the correct topology and physic parameters for your electric motor :
This tutorial gives an overview of the basic FluxMotor workflow from geometry creation to performance analysis of your motor. This covers the steps you would follow to realize pre-design steps of an electrical machine with given specifications.
FluxMotor Part Creation
Second article is about FluxMotor Part creation (link). There are two tutorials that explains how to create the excel file that can be imported in FluxMotor to analyze your geometry.
One tutorial is about using Flux software and its macros to create a rotor and stator part starting from either a CAD file or a Flux project. The other one takes a part excel file and shows how to modify it in order to have a parametrized part which geometry parameters can be modified in Motor Factory.
