Below are the highlights, watch the video recording to learn about it.
Injection Molding Solution:
- Simplified Workflow
- Meshing Improvement
- Warpage Analysis of Fiber-reinforced Parts
- Material Validation using Polymer Material Data Analysis (PMDA)
- Seamless Link with Inspire Mold
- Improvement to Sink Mark Prediction
- 2D Plots
- Fast Fiber Orientation
- DOE with Inspire Parametric
- DOE with Process Data
- Highlight Changed Field
- Timestep Controls
- Advanced Control On Mesh Size
Welding Solution:
- Ease of model setup
- Automated weld bead creation
- Visualize weld angle
- Heat Source Types
- Spherical
- Double Ellipsoid
- Heat Transfer
- Quick Weld Sequence using an interactive interface
- Type of Simulation
- Fast Distortion
- Thermal Analysis
- Coupled Thermal and Stress Analysis
