Leverage all the power of automation with Altair Pulse 2022.1
Matías Barrón_20593
Matías Barrón_20593
edited August 2022 in Altair HyperWorks
Suppose you have designed an engineering workflow that involves manual operations of multiple applications, for example, to extract data, modify parameters, execute a solver, and review results. In an engineering process, it is common to have this kind of repetitive workflows established as standard works; this means many engineers will perform the same process every time to obtain expected results. This is time consuming, human error prone and difficult to change or enhance.
Now, imagine instead of designing a process in such an old-fashioned way, you use Altair Pulse to orchestrate the interaction between applications and build a streamline solution. This is possible through its intuitive user interface and its integration with multiple programming languages. Once the solution is created engineers could focus on what is important, perform engineering; interpret results, propose design changes, solve problems, innovate, etc.
By now, you might have noticed Altair Pulse can be utilized by two kinds of users:
  1. The Author, who would design and construct the process.
  2. The Analyst, who would execute the process to explore, compare, and evaluate designs and results.
If you want to have a deeper insight on how Altair Pulse can leverage the power of automation, do not miss the following video.
Comments
  • DanielCz
    DanielCz Altair Community Member
    edited July 2023
    Can you please share some more information about this product?
    More use case scenarios and what Altair products can be used in connection with Pulse?
