Hello together,
i am struggeling with my Frontcrash model in Hyperworks radioss.
The Solver faild with the massage: ** RUN KILLED: TOTAL MASS ERROR LIMIT REACHED
I wantet to enlarge my model by "adding" a new part and meshed it. I do not understand what I forgot in the settings. bevore the extension of my model, the simulation run. the listed warnings have been there bevore, but it worked out. in the attachement i will add my *.rad and *.out file.
I hope somebody can help me with my problem(s).
.. UNITS SYSTEM
.. CONTROL VARIABLES
.. STARTER RUNNING ON 1 THREAD
.. MATERIALS
.. NODES
.. PROPERTIES
.. 3D SHELL ELEMENTS
.. 3D TRIANGULAR SHELL ELEMENTS
.. SUBSETS
.. BOX
.. ELEMENT GROUPS
.. PART GROUPS
.. SURFACES
.. NODE GROUP
WARNING ID : 692
** WARNING IN SURFACE DEFINITION
WARNING ID : 690
** WARNING IN NODE GROUP DEFINITION
.. BOUNDARY CONDITIONS
.. INITIAL VELOCITIES
.. DOMAIN DECOMPOSITION
.. ELEMENT GROUPS
.. INTERFACES
.. INTERFACE BUFFER INITIALIZATION
.. RIGID WALLS
.. RIGID BODIES
.. RETURNS TO DOMAIN DECOMPOSITION FOR OPTIMIZATION
.. ELEMENT GROUPS
.. INTERFACES
WARNING ID : 343
** WARNING: INITIAL PENETRATIONS IN INTERFACE
.. RIGID WALLS
.. RIGID BODIES
.. ELEMENT BUFFER INITIALIZATION
WARNING ID : 312
** INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
DESCRIPTION :
3516 INCOMPATIBLE KINEMATIC CONDITIONS IN MODEL
.. GEOMETRY PLOT FILE
.. PARALLEL RESTART FILES GENERATION
