What settings do I need to make to be able to calculate a 2019 simulation in 2022?
Hello Altair Team,
I startet to work on a Radioss simulation in the student version 2019. Radioss can do its job here.
Now I am able to use the full license of the 2022 version. Here the simulation doesnt run the same way. I dont get any results but it says "job complete". What settings or sth else do I have to do, that the "old" file is able to run in the new HyperWorks- Radioss version?
Thank you for quick response.
In principal, there should be no need to change the 2019 input to run it in 2022, It looks from your screenshot, like you have no termination time set in the engine file (/RUN card) though (so it is exiting after 1 cycle) but if you have no termination time, the behaviour should be same in 2019 in that case!
If you can't work it out, Can you share your input files? I can take a look for you
0 -
I have not changed anything in the file. I just wanted to run it in the other Radioss version (and then edit it further).
0 -
0 -
Yes ok, then I do not know what would cause the difference without seeing the file, there should be no need to make any change to the model to run in 2022
0 -
Which file(s) do you need?
