The Altair S-CONCRETE Professional and Enterprise editions share nearly all the same feature functions. S-CONCRETE Enterprise includes Multistory Designer, a tool used to simultaneously design all reinforced concrete beams, columns, and walls in large structural models analyzed in ETABS®.
All concrete structural elements or a select group can be imported from the ETABS® models and designed in Multistory Designer, significantly reducing the time needed to design, code-check, and create reports.
There is a video that explains more about Multistory Designer:
https://www.youtube.com/watch?v=4AAojT1cooo
