How to use the align node function in hypermesh 2023.1 like in hypermesh 2017?
Hello Prabhu I used your method, but it can't realize my targetMy target is that the white nodes should be in the line which is defined by the two black nodes
Hello Prabhu
Hi Zheng Guotao,
Can you please try using the end nodes option?
Sriramanuj Prabhu.
Please find the options below to access the Align tool.
Oh it can work
thanks
