How to measure the distance between two nodes in X,Y,Z direction based on specified local system?
Following value in X,Y,Z direction is based on global system
Hello Zheng,
In the Measure tool you need to switch from Interactive to Dimensioning. Select what you want to measure and in the pop-up you will have the opportunity to select a new system.
Marine Racollet
But there is no dimensioning option in Hypermesh 2022.3
You will need to update the already available 2023.
