S-CONCRETE is used to design and code check reinforced concrete beams, columns, and wall sections.
S-LINE can analyze and design continuous, multi-span reinforced concrete beams.
Both S-CONCRETE and S-LINE are bundled in the product Altair S-CONCRETE.
ICD, also known as Integrated Concrete Design, is fully integrated within the S-FRAME Analysis program. It is used to perform concrete design for the entire S-FRAME model. It can design single-bay continuous concrete beams, rectangular walls, and all column and beam types.
