Altair RISE
Nominate Yourself Now!
Undo function misbehaving
User: "AM_20700"
Altair Community Member
Updated by AM_20700
I'm encountering problems with the "Undo" function in Hyperworks 2022.3.
When I start the application, the function seems to work fine. After a while, I notice that CTL+Z does nothing, and when I check the menu, I have no operations available to undo. Has anyone else encountered this issue?
My "Undo" preferences are set to 100 operations and 2500 MB.
1 - 3 of 31
    User: "Chayan"
    Updated by Chayan
    Could you run the HyperworksWindowsCleanup.bat utility that is in the C:\Program Files\Altair\2022.2\hwdesktop\utility\HWCleanup folder, to remove any corrupted session files, and see if that resolves the issue.
    User: "AM_20700"
    OP
    Updated by AM_20700
    Unfortunately, this did not resolve the issue.
    I've attached a video of the behavior.
    User: "Altug Otsar"
    Updated by Altug Otsar
    Hi, I have same issue also and its getting very annoying. I did run cleanup file it worked but after a while it started again. Did you solved with different way?
