I'm trying to calculate hot spot stress via FBD. I'm need to sum the direct nodal stress and the secondary stress (resulting from moments) in a specific direction.
But my nodes follow a curved path, so the relevant moment axis changes.
For example, I want to sum the nodal forces (in red) and the nodal moments that create forces along the same direction. For a portion of the path, it's the Y-moment (in green) and then it transitions to the Z-moment (blue).
When I export the FBD nodal forces and moments via a table, I can't extract the relevant moment.
Is there a way to have the FBD system track the elemental system at each node?
Is there a way to set a user system that is normal to the element edge at every element?
