How can I extract the internal force at a specific location or along a line?
For example, I'm applying a force at the shaft and interested in the force at the joint between the shaft and the plate (obviously, in this example the force is equal to the applied force. But I'd like to extract forces in locations where the value is not obvious). How can I extract the force along the highlighted line?
Thanks.
