Is it not possible to define a base node within the "rotate" window?
If I want to set the origin as my base node, but I don't have a pre-existing node defined at the origin, do I have to abort the operation, exit the tool, create a temp node at the origin, restart the "rotate" operation, and then select the temp node that I just created as a base node?
