I'm analyzing a vibrating system that operates at 15 Hz. The analysis is simulating a ramp up from 0 Hz to 15 Hz. There is resonance at 3 Hz. I'm specifically looking at the force through the upper crossbeams.
 If I set a measure at the crossbeam RBE3 element central node, and animate the results in transient mode, I get a spike at 3 Hz with a value of 7072 N:
 However, if I set the subcase load to 3 Hz and animate the results in sinusoidal mode, I get a max value of 6943 N.
 What's going on?
