I am simulating a motor drive system using PSIM to be implemented on DSP (F28335). I am using SSI encoder (data sheet is attached) to get the rotor position and using SPI blocks to interface the encoder with the DSP. I’m confused about setting some of the parameters in the SPI blocks. I went through the SPI tutorials and the encoder data sheet many times and could not specify the following items: start initial command value, received data command, data bit position, SPI initial command value in the SPI input block parameters.
