This example is given here
https://community.altair.com/community/en/edem-tutorial-edem-fluent-heat-transfer-in-fluidized-bed?sys_kb_id=9849d9761b0120d4c4dfdbd9dc4bcbfb&id=kb_article_view&sysparm_rank=1&sysparm_tsqueryId=de496f59dbbe35d4cfd5f6a4e296191e
shows how to do get the coupling to work between EDEM-Fluent.
In this model the body force applied is due to difference in temperature for the particles.
Suppose i want to apply the body force of aerodynamic drag from fluent instead of using the in built models of altair such as Alexander-Morsi drag. what should i do?
My objective is i have a chain hanging from a ceiling and i want to blow air from the left side. This blowing of air is going to be done in fluent by specifying the inlet and outlet
how should i take the flow field value from fluent to EDEM using the coupling?
