I am trying to communicate with an i2c device BMI160 on the Sensors BoosterPack by using F28069M LaunchPadXL. And I find there is an example named eepromReadWriteF28027, but it's doesn't work even I set CPU to F28069M. I am new to I2C field, is there any easy Embed example that can work properly to communicate between BMI160 and F28069M for reference?
p.s. the attachment program is modified from the example 「eepromReadWriteF28027」, what I need to do is to read gyro readings from BMI160, the program can run, but the readings don't change when I move or shake LaunchPad.
Thanks! Jeff
