Use eCapture to capture PWM signal
I want to use eCapture to get rising edge of a PWM signal which produce by F28069M, here is the set up:
1. Produce a 15Hz signal by ePWM, and output to GPIO0,
2. Use eCap to detect rising edge, and Mux pin set to GPIO11, connect to a "plot" block,
3. Connect GPIO0(Pin 40) and GPIO11(Pin 75) by physical wiring,
4. Tools→Code Gen→Compile→Download, and Go
and there is nothing in "plot" block, is there anything wrong with these set up?
p.s. I've checked ePWM output with oscilloscope(RTB2004), the frequency which I set is correct.
Thanks.
The procedure you followed works on the target. In order to read the signal on pins you would need to run the diagram in HIL .
1. Create a compound block of the logic.
2. Select the compound block .
3. Click on Tools>>Codegen>> Select the option shown below
4. Click on Compile and quit.
5. Place the target interface block from Embedded>>Piccolo>> Target Interface>> Target Interface.
6. Select the "run in real time" option from system>> System Properties.
7. Run the diagram "green button".
Attached the modified diagram.
Girish
Girish
