Simlab Streamers Failed to compute streamers
![eaton1](https://us.v-cdn.net/6038102/uploads/defaultavatar/nLP0QHCLH24WL.jpg)
I have been generating streamers and upon changing the model I have occurred an error which I cannot seem to understand the root of.
I am getting the following in the log. If anyone can describe the error it would be very helpful; thanks.
Flux3D (application 2022.2) running
OCRI04 => Retrieval of INTEGER attribute aborted
[65499|1715351135768|123|INFO ][ErrorManager|ErrorManager.createFortranException] : Type: 500 Message: OCRI04 => Retrieval of INTEGER attribute aborted
[65500|1715351135768|123|INFO ][Fortran.Error|ErrorManager.createFortranException] : Type: 500 Message: OCRI04 => Retrieval of INTEGER attribute aborted
ELRLV5 => failed
[65501|1715351135768|125|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: ELRLV5 => failed
ELCPOS_3 => Position not found
[65502|1715351135768|127|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: ELCPOS_3 => Position not found
EL_R_PROX_REG_DEF => Failed
[65503|1715351135768|129|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: EL_R_PROX_REG_DEF => Failed
EL_R_PROX_REG_DEF_1 => Failed
[65504|1715351135768|131|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: EL_R_PROX_REG_DEF_1 => Failed
[65505|1715351256999|139|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: OCRI04 => Retrieval of INTEGER attribute aborted
ELRLV5 => failed
[65506|1715351256999|141|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: ELRLV5 => failed
[65507|1715351257007|143|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: ELCPOS_3 => Position not found
[65508|1715351257007|145|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: EL_R_PROX_REG_DEF => Failed
[65509|1715351257007|147|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: EL_R_PROX_REG_DEF_1 => Failed
OCGNBR => Retrieval of number of attribute aborted
[65510|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: OCGNBR => Retrieval of number of attribute aborted
OCZNBR => Retrieval of INTEGER aborted
[65511|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: OCZNBR => Retrieval of INTEGER aborted
OCZDIR_DYNAMIC_ALLOCATION => Retrieval of direct relation aborted
[65512|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: OCZDIR_DYNAMIC_ALLOCATION => Retrieval of direct relation aborted
LGZALA => Fatal error
[65513|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: LGZALA => Fatal error
FAZLAT_2 => Fatal error
[65514|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: FAZLAT_2 => Fatal error
FAZLAT_1 => failed...
[65515|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: FAZLAT_1 => failed...
FACITS => Failed
[65516|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: FACITS => Failed
GBD_C_COARC_PARA => Evaluation interrupted
[65517|1715351810420|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: GBD_C_COARC_PARA => Evaluation interrupted
GBD_FNUM_PARA => Evaluation interrupted
[65518|1715351812792|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: GBD_FNUM_PARA => Evaluation interrupted
GBD_FNUM => Evaluation interrupted
[65519|1715351812804|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: GBD_FNUM => Evaluation interrupted
BAFOC2_1 => Evaluation failed
[65520|1715351812804|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: BAFOC2_1 => Evaluation failed
BAFOC2 => Evaluation failed
[65521|1715351812804|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: BAFOC2 => Evaluation failed
BAFOCC => Evaluation aborted
[65522|1715351812804|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: BAFOCC => Evaluation aborted
evaluateInstances => failed
[65523|1715351812804|1|INFO ][Fortran.Error|ErrorManager.addMessageToException] : Type: 1 Message: evaluateInstances => failed
[65524|1715351812804|1|INFO ][Fortran.Error|ErrorManager.insertMessage] : Type: -1 Message: evaluateInstances : Execution failed.
Could you please share the model? We will check and get back you.
0 -
Would it be possible to get a link to upload the file? As the data would need to be covered under our existing NDA. Thanks.
0 -
Charles Sims said:
Kindly upload the model to my drop box.
https://ftin.india.altair.com/filedrop/~4vEIpu
Thanks,
Santhoshkumar
