Can you have a foundation wall where the footing extends a set amount past the ends of the wall, and can you put point loads anywhere along the length of the wall
Hi Steve, I see you sent an email with the same question sharing a PDF, we will get back to you through there.
I'll post the reply here as well,
What you want to do is possible, when creating a wall footing you can define the Wall strip extrusion distance
Best,
Tayen Aguilar
Altair Support
