Best I can suggest is to review the tutorial ACU-6100 that comes with the AcuSolve Help documentation. It covers a bit of meshing and preparing with HyperMesh. I do know you need to have visible the elements (volume/surfaces) you wish to export. You could also try meshing with AcuConsole if the geometry is clean/closed and requires no modification.
How are you trying to export the mesh from HM?
