The problem is as follows.
After 1 cycle, run file stops.
Why doe it happens?
How do I do?
Thanks
My guess is there is some issue with your engine file filename_0001.rad.
Maybe you don't have an end time defined and thus there is no endtime and it just runs one cycle?
RUN/Cantilever_beam/1/0.3
Thanks,
Andy
Thank you for your answer
