Hi
This figure shows the accelerations on the node using /TH/NODE and /TH/ACCEL.
F_cut of /ACCEL is the recommended value (1650Hz).
Filter CFC1000 (F_cut 1650Hz) is applied the acceleration using /TH/NODE.
Why are they different?
Thanks.
