I need to perform Linear Time series with Temperature loads with temperature dependent material Properties and please let me know how the results vary with linear static
MATT1:Bulk Data Entry Specifies temperature-dependent material properties on MAT1 entry fields via TABLEMi or TABLEG entry.
Refer attached deck.
Thanks Rahull
This case is Temprature dependent Properties with Time dependent run,the above shown curve is sudden heating and sudden cooling.This in need to stimulate it .Please let me know your views and sample deck.
with regards
Joseph Malvin Raj M
