I want to see how the GAP between two 3D Solid Elements changes before and after preload and external load.
As the image shows , the initial gap is aproximately .1 mm and after preload, aproximately 0mm. My goal is that after an external loading this gap is NOT greater than .2 mm.
What would you suggest for:
Contact Property Card (Clearance, Stiffness, Tracking, SRCHDIS, MORIENT and so on)?
Thank you!
