What is the difference between CORD2R and CORD3R? What are their properties?
If I reference joints to a specific coordinate system what would the difference be with CORD2R and CORD3R?
Thank you!
the difference is in the creation process and in their behavior:
from Optistruct User's guide:
Coordinate Systems In geometric nonlinear analysis there are moving and fixed coordinate systems. Rectangular coordinate systems that are defined thru grid points (CORD1R, CORD3R) are moving with the deformations of the model. Systems defined in terms of point coordinates (CORD2R, CORD4R) are fixed. The behavior of loads depends on the coordinate system referenced. If the loads FORCE, MOMENT are desired to be follower forces, a CID that references a moving coordinate system (CORD1R, CORD3R) must be defined. Otherwise these loads are not following the deformation. PLOAD always follows the deformations.
Thank you for your response!
This was extremely helpful!_)
